Limited Slip for Automatics
Old Mar 1, 2003 | 01:50 AM
kscoyote's Avatar
Default Limited Slip for Automatics
Does anyone know of a LSD for the GTV6 Auto?
Old Mar 3, 2003 | 02:55 AM
Type-H's Avatar
I dont know if it will work, but my friend just stripped a 02'SE-R's limited slip and put it on his manny GTV6. They are the same diffs but the SE-R's is better than the Tib's
Old Mar 3, 2003 | 09:01 AM
lantraluvr's Avatar
Vehicle: 1999 Elantra
They can't be the same. The Tib's is not an LSD while the SE-R's have LSD's.
Old Mar 4, 2003 | 04:16 AM
the SE-R Vspec and the V6-6speed share Tranny internals. The SE-R Vspec Diff can be purchased for about $450 from any nissan dealer, and put into a V6 6-speed tranny to replace the stock open differential.
Old Mar 4, 2003 | 07:15 PM
Russ's Avatar
But if I'm not mistaken, the tib 6-speed and tib auto are completely different. At least for internals. I doubt something from inside a 6-speed would be even close to bolting up in the auto.
