How often do you double clutch?
Old Aug 4, 2010 | 07:14 AM
Zeebone's Avatar
Vehicle: 2007 Tib
Default How often do you double clutch?
Curious if there are those here who do it alot, or only at certain times like when they downshift, or race, etc...
Old Aug 4, 2010 | 07:38 AM
No point
Old Aug 4, 2010 | 08:51 AM
'treezy's Avatar
I triple clutch on the daily. ..b*tches But only because I am a professional (and because my right leg is stronger than my left leg).
Old Aug 4, 2010 | 08:53 AM
Pssshh....I quadruple clutch yo! My 2 legs, plus the passengers 2 legs! Beat that fools!!!!
Old Aug 4, 2010 | 09:05 AM
'treezy's Avatar
Seriously though. No point, (in a Hyundai). End of discussion.
"Double Clutching" is advantageous in non-synchronized transmissions found in heavy machinery, big trucks, motorcycles, and some race-only applications. The reason they are seen on the racetrack are twofold; one, for their rawness and simplicity and two, for their speed. A synchronized transmissions has brass friction material that is prone to wear and breakage where a non-synchronous transmission is just forged steel gears. They are quicker because there is less sh*t going on in the transmission when shifting, if you've ever driven a race/track car with such a transmission you'll know exactly what I mean once you shift.
One thing I've commonly seen with daily driven track car owners is that they will modify their synchronous transmission to act and feel more like a race trans by cutting off half of the teeth (or "dogs") on the synchros to speed up the shifting process. It works, but not for very long (on a daily) as the downside is increased wear and tear.
Old Aug 4, 2010 | 10:09 AM
I only do it when I hit the naawz and the floor panel falls out after I get a danger to manifold indicator.
Old Aug 4, 2010 | 11:37 AM
LOL forgot about the danger to manifold. I almost never get that.
Old Aug 4, 2010 | 12:01 PM
Turboron_99's Avatar
Vehicle: 13 Gen Coupe Ult.
I beat all yall clutcherz!!!
How about no clutching, eat that dust and metal shavings!!!!!
Old Aug 4, 2010 | 01:42 PM
When I drive a semi truck, it's double clutching or no clutch at all. Outside of that don't double clutch.
Old Aug 4, 2010 | 04:21 PM
'treezy's Avatar
To answer original post question..
About as often as I double dutch.. [/thread]
