jumping out of gear (auto)
Old Nov 18, 2002 | 05:16 AM
TiburonGuy99's Avatar
Vehicle: 99 Tib
Default jumping out of gear (auto)
sometimes when I floor my auto and take off then when i let off and get back in the gas it goes into nuetral even though its still in drive i have to put in neutral then back in drive to get it into gear my warranty is out so can't take it back to hyundai and the other day i was sitting in the turning lane when I went to turn it jumped into neutral almost got hit but i rolled back into the turning lane and then it went back into gear. it hard to explain hope i did it right anyone know whats wrong?
Old Nov 18, 2002 | 10:11 PM
plantenutz's Avatar
my guess is that your tranny is going.This is what was happening to my first one,and a few weeks later it kept getting worse and worse,then it finnally went.Luckly i was coverered under warrenty.hope it gets better,because if it doesn't you likely going to need a new one.
P.S. do you drive your car pretty hard?
Old Nov 18, 2002 | 11:35 PM
Shadohh's Avatar
You could spend $80 and have the dealer diagnose the problem to tell you what is exactly wrong.
You could go on ebay (used) call st charles (hyundai discount for a new one) and get it replaced.
I would recoommend if you have the cash to get another one put in. Send your torque convertor to levelten and get the upgrade. I will give you tranny more responsive so you wont need to beat it so hard.
I recommend the swap to 5spd since its out of warranty and the Automatics made for the BETA engine have always been ****ty.
Try this. Start the car and go for a drive down the road and back and make sure the car has warmed up. No leave the car on put the E-brake on. Shift from first to second to drive and then to park. Take the dip stick out and check your transmission oil. It should be Redish.
Its its blackish or brownish its burnt.
If its burnt replace the fluid immediatly. And see if that helps. Also since you are in TX you may want to invest in a transmission cooler.
[ November 19, 2002, 06:37 AM: Message edited by: Shadohh ]
Old Nov 19, 2002 | 10:18 AM
Vehicle: 99 Tib
money is tight right with it being the holidays and just now getting caught up with my bills i'll check the tanny oil. frown
Old Nov 19, 2002 | 10:46 AM
Jaime's Avatar
Yeah its slipping, but if u still have warranty, they can, replace it with a new one for free under warranty.... wink
Old Nov 19, 2002 | 10:49 AM
Vehicle: 99 Tib
no warranty sad.gif its out
Old Nov 19, 2002 | 11:02 AM
Jaime's Avatar
Sorry to hear that, but have u tried to buy extended or Extra warranty, that is what my mom did for her 00 Impala..
[ November 19, 2002, 06:06 PM: Message edited by: Jaime ]
Old Nov 19, 2002 | 11:07 AM
long's Avatar
my tranny has been ****ty ever since i got the car. replaced it twice already. i dont race on the current one and i installed a tranny cooler and new performance fluid. our trannies just get so hot they practically just disinigrate. sorda most likely its shot or just some linkage on the gears. either that or your computer is telling it to go into neutral. which is unlikely. time for a rebuilt.
Old Nov 19, 2002 | 11:26 AM
Vehicle: 99 Tib
where can I buy the tranny cooler?
Old Nov 19, 2002 | 04:17 PM
Shadohh's Avatar
Dont invest in a cooler, till you have checked the coniditon of the fluid and told us.
remeber it has to be done AFTER a short drive.
how many miles is on the transmission and when was the last the fluid was change anyway?
[ November 19, 2002, 11:18 PM: Message edited by: Shadohh ]
