Automatic Tranny fluid
Old Jul 3, 2002 | 10:17 AM
Lobert's Avatar
Default Automatic Tranny fluid
Can someone please tell me what "GENUINE DIAMOND ATF SP-III" is the same as?????????? I just tried Autozone and they had no idea.
Old Jul 3, 2002 | 06:09 PM
Katana's Avatar
I tried everywhere to get that crap and they all said dealer only. You'll have to make the trip to the dealer to get it, and get ready to bend over! I was charged about $8.50 a quart. I guess Hyundai has to get money for their 100k warranty any way they can!
Old Jul 3, 2002 | 07:04 PM
Any "SP-III" rated Tranny Fluid will do the trick. You do not need to go with the dealership/hyundai brand.
Old Jul 4, 2002 | 01:25 AM
d_m_kolb's Avatar
Amsoil has trany fluid with the same specs as what you want. E-mail them and they can give you the exact one for that.
www.amsoil.com
Old Jul 6, 2002 | 05:28 AM
da nam's Avatar
ask for type 7176 atf or val.part # 333
Old Jul 6, 2002 | 09:24 AM
Spatch359's Avatar
How about Mercon/Dexron III? A guy at Advance Auto said it would work with no problems. Just want to make sure before use it...
Thanks!
Spatch!
Old Jul 6, 2002 | 09:45 AM
9o7TiB7o9's Avatar
What are the benefits of this type of tranny fluid?
Old Jul 6, 2002 | 10:58 AM
Lobert's Avatar
9o7TiB7o9, if you are talking about the SP-III, as far as I am concerned, there is no advantage. It's a royal pain in the @$$. It's a dealer only item.
Old Jul 6, 2002 | 11:39 AM
Spatch359's Avatar
So, do y'all think that the Mercon/Dexron III will work? The HMAService Webtech said to use:
Automatic transmission fluid : GENUINE HYUNDAI ATF SP-II M.
for a 2002 Elantra GLS Auto. Should I use the Dexron or go to a different type?
Thanks,
Spatch!
Old Jul 7, 2002 | 10:43 PM
Spatch359's Avatar
Just went to my nearest Hyundai Dealer and bought some SP-III ATF Fluid. They wanted $5.50 eek! a quart which isn't as bad as $8.50, but is still worse than Dexron III @ $1.83 a quart...
Spatch!
