clutch chatter
Old Mar 15, 2010 | 11:16 AM
tiburon423's Avatar
Vehicle: 2001 Tiburon
Default clutch chatter
I had my clutch replaced about 6 months ago and I never had the flywheel resurfaced. I have a little bit of clutch chatter and Im wondering if im taking a chance of ruining my tranny. Im a n00b when it comes transmissions so go easy on me. lol
Old Mar 15, 2010 | 12:21 PM
shouldve had the flywheel resurfaced
the chatter is more than likely due to the fact that the clutch isnt holding true on a warped surface
typically the trans will be fine, but the clutch isnt gonna last long
Old Mar 17, 2010 | 01:32 PM
2001hyundaired's Avatar
Vehicle: 2001 hyundai Tiburon
Clutch chatter is more of an annoyance than anything. It will wear out quicker if you didnt resurface your flywheel but its not anything to worry about too much.
