clutch problem????
Old Jan 10, 2003 | 01:06 PM
Tibby Pimpin's Avatar
Default clutch problem????
What the problem is my cruze controle will not work unless I pull up on the clutch peddel,not to big of a deal but I am going to panama city beach for spring break and I am driving form Indiana and I would like to have cruze if u now what I mean.Oh I have a clutch masters stage 3 on it and tonight I just found out like when i push in the clutch in to the floor and rev it up like around 5500 it pulls a little well the car kinda moves,so any help would be great.
Old Jan 10, 2003 | 10:34 PM
Shadohh's Avatar
You have to little swtiches, that tell the car when the clutch is pressed in and when it is not.
The one is miss set. If you look under your dash you can seen the little white bulbs. You will need unlock the nut and turn them and relock the nut, so they the pedal once again contacts those switches.
