Automatic Tranny
Old Jan 22, 2003 | 09:47 AM
Tibby2K's Avatar
Default Automatic Tranny
Is it normal for an automatic transmision to hit the rev limiter?
While driving to work this morning I heard a wierd noise, when I looked down at my tach, the needle was bouncing aorund.
I was driving it pretty hard (like usuall), but i've never been able to make it do that. No I wasn't shifting it manually.
Was it beacuse of the bitter coldness outside?
2000 Automatic Tiburon
Old Jan 22, 2003 | 10:39 AM
turbulence's Avatar
oh, you know how to fix that?...do the swap um, when you say it hit the rev limiter, did it hit it and shift, or bounce off of it? you mentioned the cold weather. was your engine warm? if not, you shouldn't drive it hard at all, unless you want your pistons to f**k up the cylinder walls if it happend once, don't worry about it. if it is a perpetual thing, take it to the dealership.
[ January 22, 2003, 05:41 PM: Message edited by: turbulence ]
Old Jan 22, 2003 | 10:57 AM
Tibby2K's Avatar
turbulence:
It was bouncing off the limiter, so lifted on the gas then it shifted. It wasn't fully up to normal temp.
Old Jan 22, 2003 | 12:37 PM
Viper966's Avatar
mine does that when the engine is cold.. i did it one time... now i let my car fully warm up before going WOT if i can help it
Old Jan 25, 2003 | 02:46 AM
turbulence's Avatar
i was hoping random would come on with some more info than i have. but it's just not recommended that you run the engine high in the rpms until it's FULLY warmed up. when the engine's cold, the pistons might shimmy up the cylinder and scrape the walls.
