Advice on PP&Clutch
Old Apr 2, 2003 | 03:03 AM
KillerShark68's Avatar
Vehicle: 2007 Tiburon
Default Advice on PP&Clutch
If you say...had a stage 3 clutch, could you get away with using the stock preasure plate? Or would it not be wise, and just get a better preasure plate?
Old Apr 2, 2003 | 05:00 AM
in what application? N/A? Turbo? Nitrous?
Old Apr 2, 2003 | 08:40 AM
In a turbo application for 250-300 hope to have HP.
Old Apr 2, 2003 | 08:53 AM
onpol's Avatar
Aim for the strongest of all. I have tried stage 3 and 4 from CM and both have been maxed out at 300WHP
Old Apr 2, 2003 | 09:34 AM
god no, for 250-300 WHP you would never make it with the stock pressure plate.
You would need a stronger pressure plate to handle that much HP/Torque.
