BETA 5spd Gear Ratios
Old Oct 29, 2002 | 04:45 PM
Shadohh's Avatar
Default BETA 5spd Gear Ratios
Lets talk Gear ratios. If you slap on some 190whp on a low boosting turbo. driving in fifth at 80mph at 4rpms is really gay.
Also since fifth is weak, I would like a longer fourth gear. I understand HMA is in accurate so its uselees in this search.
Does, Anyknow if the elantras gears are long in fourth and fifth and if the final drive ratios are any differet?.
If you change the final drive, you can make all the gears top out a different speeds. right? Making first goto 40mph would be nice.
My main goal is 80 at 3000rpms.
And I am thinking a higher top speed in fourth would be nice, since you can't put get on it in fifth.
Random, you are making 170whp? Are you punching it in fifth if so, is it holding?
Old Oct 30, 2002 | 12:38 AM
Right now, my car is tuned for 180 WHP and 197 Ft lbs...and 5th gear is holding up fine.
To be honest, I wouldn't worry about it till closer to 250 WHP. 5th gear is weak, but not THAT weak.
Next, the only way 5th would break is if you floored it in 5th. If you are flooring it in 5th gear, better acceleration can be had by downshifting to 4th anyway...thus elimitating the problem.
In response to gear ratios...I'll research them and post them up.
Old Nov 6, 2002 | 03:39 PM
Here ya go...
Strange thing... www.hmaservice.com lists ratios for a 6-speed 2.0L tranny
Old Nov 6, 2002 | 03:44 PM
Shadohh's Avatar
Old Nov 6, 2002 | 04:10 PM
Shadohh's Avatar
::;sighs::: This sucks. most I could get was 3500 at 80mph instead of 3800 at 80.
2 Things. Can you list the 6sd ratios. just curious of them. Also do you have any part numbers?
Could you list the elantra gearing as well. They have the same tranny but I am hoping for wider gears.
[ November 06, 2002, 11:19 PM: Message edited by: Shadohh ]
Old Nov 7, 2002 | 12:30 AM
Shadohh:
6speed and elantra 5 speed ratios are there.
Old Nov 7, 2002 | 02:07 AM
Shadohh's Avatar
my bad. I printed it out and it cut some of.
Old Nov 7, 2002 | 08:41 PM
lantraluvr's Avatar
Vehicle: 1999 Elantra
None listed for 1.6 Beta tranny?
Old Nov 13, 2002 | 11:24 AM
batman's Avatar
Vehicle: 01 Tiburon
it says that 97-2000 tibs 4th gear is 1.031 and 2001 tibs 4th is 1.061 whats the advantages disadvantages of this one way or the other
i have a 2001 and was wondering if it would be worth swapping them
Old Nov 13, 2002 | 05:35 PM
Shadohh's Avatar
Its liek a 3mph difference. Aint wworth it.
