Beta 5 speed on Alpha Motor?
Old Feb 28, 2003 | 02:32 AM
Default Beta 5 speed on Alpha Motor?
Has anyone done a conversion to use the beta Tranny on an Alpha motor?
I remember hearing that some folks were going to try it, but I don't know if they did, and if it was ever successful.
Anyone have details?
Old Feb 28, 2003 | 02:58 AM
Ace_Cobra's Avatar
i didnt see the utility of this swap.
maybe because the alpha is too boosted and the original tranny isnt enough..
no?
Old Feb 28, 2003 | 05:37 AM
skierd's Avatar
Vehicle: 1997 accent L
I think Beppomarx on Hyundaiperformance.com is in the middle of doing it. Check the accent forum over there.
Old Feb 28, 2003 | 02:32 PM
Denisst99's Avatar
tranny will bolt right up to the alpha block,you'll need custom axles,the mounts will need some work but the clutch is the problem, the beta clutch is a bit too large for the beta flywheel, and you can't just use the alpha cluth because the beta tranny use a pull type diaphragm,maybee a clutch fro ma different car wil lfit the alpha flywheel and be a compatible puller type, i didn't try to do it so i can't comment more then that
Old Feb 28, 2003 | 06:14 PM
lantraluvr's Avatar
Vehicle: 1999 Elantra
Use a clutch from a 1.6 Beta. I think it has a "push" type diaphragm.
