BUSTED SHIFTER
Old Aug 5, 2002 | 01:19 AM
arn's Avatar
arn
Default BUSTED SHIFTER
I think I'm the first on tho break a B&M shifter. So, for those of you that has one beware of the bottom screw that hold the bushing. That particular piece broke of since it's made of aluminum. I did'nt know how but it broke. I contacted B&M and they will send me a replacement screw. I don't know how to call it so I'm calling it a screw on the bottom of the shifter. I still like it better than stock.
Old Aug 5, 2002 | 02:10 AM
Veniston's Avatar
Well, you're the first one this week anyways...
http://www.teamsr.org/UBB/ultimatebb.php?u...c;f=16;t=002865
Hrm, sounds like a design flaw to me. I'll stick to my welded SR shifter, thanks. wink
Old Aug 5, 2002 | 02:13 AM
Solo-Baric's Avatar
I'm the one it happend to last week. I called them on mondy and had the new part on saturday. When you get the one part it, it's probally gonna be steal. At lest mine was. Then now is a lot thicker then the orginal one. But i'm gonna start carrying the stock shifter in the car just in case. But it only took me 5 mins to take the stock shifter back out and put the b&m back in.
