READ swapping to beta tranny
Old Mar 12, 2010 | 01:19 PM
ACCENT2.0t's Avatar
Vehicle: 1997 hyundai accent swap 2.0 turbo
Default READ swapping to beta tranny
okay i have a boosted beta in a 97 accent and i just had a 99 elantra 5 spd tranny put in (elantra is the same trans as a tiburon but when you buy them used they arent as beat as tiburon trannys) and i was wonder how different it will feel acceleration, top speed, on boost, ect so if anyone can offer any insight it be great ill post a deffinite update and some new pics of it monday sometime when its done
Old Mar 12, 2010 | 03:15 PM
they are NOT the same transmission
elantra transmissions > tiburon transmision
longer gears
realize that (and this is just a IIRC) if you put a beta trans in your stock alpha axles will no longer work
if i was gonna go through the trouble id look around for a beta 2 elantra transmission (2003 model year is pretty strong with good gearing)
Old Mar 12, 2010 | 03:35 PM
ACCENT2.0t's Avatar
what do you mean they arent my performance shop said they are the only thing needed is an adapter plate to connect a 99 elantra trnny to a 99 tib motor
Old Mar 12, 2010 | 03:52 PM
adapter plate?
wtf?
dont need that at all
the trans exterior is physically the same
the gearing(ie important part) is different
the elantra trans has better gearing
Old Mar 12, 2010 | 05:21 PM
ACCENT2.0t's Avatar
theres an adapter needed
Old Mar 12, 2010 | 05:22 PM
ACCENT2.0t's Avatar
and thats where youre wrong the elantra NEEDS an adapter plate to bolt up ill post a part number on monday chairhit.gif it costs about 90 bucks.... so uhm whats the saying?!? oh yea owned and way to get off the posted topic i ask what the driving difference is
Old Mar 12, 2010 | 05:40 PM
WytchDctr's Avatar
Vehicle: 14 EGT 2.0
I can't wait to see what this plate is. The bolt pattern on the engine is the same, the bolt pattern on the bell housing.. would have to be the same. The trans is the same size. The only "adapter" anything ive heard of people having to use is if you want to run a 1.8 flywheel. The 1.8 doesn't have some ring thing where it bolts to the crank, you can find said adapter on the autos (ref Shadoh's trans swap). I believe it sits behind the flex plate.
Old Mar 12, 2010 | 05:48 PM
as i said in the shout box...i mustve installed the 2001 transmission onto my 2000 elantra with pure effing magic
oh and the 98, 99, and 03 elantra transmissions i had on there also installed with said effing magic
elantra transmission has BETTER GEARING which is infact what you asked for
longer gears
lower rpms on the freeway
ALL YOUR OWNS BELONGS TO YOU
Old Mar 12, 2010 | 05:51 PM
ACCENT2.0t's Avatar
im not sure what adapter because i thought it was a direct bolt up to like i said earlier theyre the same trans except the gears are a little different but the shop said theyre waiting on some adapter plate to come in to install it so ill get a part number monday when i go in
Old Mar 12, 2010 | 05:55 PM
ACCENT2.0t's Avatar
HERE IT IS IN ALL CAPS FOR EVERYINE WHOS HAVING A HARD TIME UNDERSTANDING THE 1-9-9-9 E-L-A-N-T-R-A TRANSMISSION WILL NOT FIT ON A 1999 TIBURON MOTOR WITHOUT AN ADAPTER
