2003 tib 6 speed a SE-R tranny.
Old Nov 18, 2002 | 08:34 PM
xxxmonoxidechild's Avatar
Default 2003 tib 6 speed a SE-R tranny.
i was just reading up in the january SPORT COMPACT CAR, and it mentioned the the 6 speed tranny in the 2003 tiburon is a nissan SE-R spec-v's gearbox. i just thought it was intresting and thought id share.
Old Nov 18, 2002 | 11:40 PM
Shadohh's Avatar
I know the rumor started because both transmissions are made form AICHI. As for them being similar? I doubt it.
Belling housing and gear ratios should be different.
Now it could be possible if they have a LSD for the SE-R it would work in the Tib.
I woudl check the phantom grip LSD. IF they use the same partnumber for both cars. Then they are the same diffs.
But to be honest. I hear alot of trash about the 6spd having 3rd gear syncro problems and some others.
No I wonder. do SE-R have the same problem? Are the giving hyundai a ****ty quality cause it hyundai? Or is hyundai having them make a less quiality transmission comapred to what they make for nissan?
Old Nov 19, 2002 | 04:02 AM
Viper966's Avatar
checking the phantom grip part number wouldnt do much good as they are pretty universal units.... id check flywheel sizez and teeth
Old Nov 19, 2002 | 04:41 AM
SPIKE's Avatar
I heared this on NT.com also
Old Nov 19, 2002 | 04:19 PM
Shadohh's Avatar
No, from what I see, the Phantom Grip sitll makes kits for certian cars.
They have a part numebr for a Honda Civic kit, and a Hyundia Tiburon kit.
