2003 tib 6 speed a SE-R tranny.
i was just reading up in the january SPORT COMPACT CAR, and it mentioned the the 6 speed tranny in the 2003 tiburon is a nissan SE-R spec-v's gearbox. i just thought it was intresting and thought id share.
I know the rumor started because both transmissions are made form AICHI. As for them being similar? I doubt it.
Belling housing and gear ratios should be different. Now it could be possible if they have a LSD for the SE-R it would work in the Tib. I woudl check the phantom grip LSD. IF they use the same partnumber for both cars. Then they are the same diffs. But to be honest. I hear alot of trash about the 6spd having 3rd gear syncro problems and some others. No I wonder. do SE-R have the same problem? Are the giving hyundai a ****ty quality cause it hyundai? Or is hyundai having them make a less quiality transmission comapred to what they make for nissan? |
checking the phantom grip part number wouldnt do much good as they are pretty universal units.... id check flywheel sizez and teeth
I heared this on NT.com also
No, from what I see, the Phantom Grip sitll makes kits for certian cars.
They have a part numebr for a Honda Civic kit, and a Hyundia Tiburon kit. |
