help with an auto tranny....
Old Mar 15, 2003 | 06:53 AM
Joker's Avatar
Default help with an auto tranny....
Everytime I drive my car about 100 miles or more without stopping I get the check engine light....I've had the tranny rebuilt 4 times in the last 6 months and everytime they keep pulling the same codes (IE: Solenoid A stuck on; incorrect gear ratio; Electrical circuit stuck on; and another code for the torque converter)....my question is this. Could this be a problem with the car's computer sending wrong signals?? If so how much would it cost to get it reprogrammed/a new one????
Old Mar 15, 2003 | 08:14 AM
lantraluvr's Avatar
Vehicle: 1999 Elantra
MAybe it is a good time to swap to a manual tranny. Search around for info regarding a m/t swap.
Old Mar 15, 2003 | 08:35 AM
Joker's Avatar
The only problem with that is my wife also has to drive this car and she can't drive a manual....she can barely drive an auto lol.....
Old Mar 15, 2003 | 12:28 PM
ask your dealer to look at the TCM to verify that the TCM is working properly. Some TCM's were known to have problems and they should have been swapped out with a newer/known good TCM.
Check your service records to see if your dealer ever replaced your TCM.
