need a performance clutch????
Old Sep 9, 2002 | 02:01 PM
xxxmonoxidechild's Avatar
Default need a performance clutch????
i need a clutch for my 2000 tib, and cant really find any thing for the beast? any one ever got a stage 1 or 2 for your tib? also i am intrested in a aluminum fly wheel if there is a such thing. im hoping for it to hit around $600 bucks so i wont be broke. if anyone knows of a site that has what im looking for, hook me up. thanks.
Old Sep 10, 2002 | 06:26 AM
ok, has no one ever done a performance clutch to there car??? am i the first to try it?
Old Sep 10, 2002 | 06:28 AM
JAWS 021's Avatar
no
i got a fidanza lightweight flywheel and a Stage 4 clutch
try
www.hve.com.au
www.rpw.com.au
Sharkracing.com (distributes for both of them)
Koremotorsports.com
Clutchmasters.com
run a search on fidanza flywheel
Also run a search on performance clutch
Youll find answers to all your questions
I do recommend you do other mods before you switch out your clutch (thats if your car is stock)
[ September 10, 2002, 01:31 PM: Message edited by: JAWS 021 ]
Old Sep 10, 2002 | 06:30 AM
flywheels are available from RPW, HDK or Fidanza
Clutches are available from just about every major aftermarket clutch company.
If you told us WHAT you were going to USE the clutch ON...it would help. How much HP? What kind of use? (daily driver or drag strip only)...etc..etc..
if you search on CLUTCH you will find a WEALTH of info.
Old Sep 10, 2002 | 07:28 AM
well my car is stock at the moment but im going to do an injun intake, and a full exuast. but im goin to do the clutch now. i ordered a stage 2 clutch from kore motor sports and still really cant find a flywheel i like that is priced under like 500 bucks.
Old Sep 10, 2002 | 07:31 AM
JAWS 021's Avatar
ok
go to groupbuycenter.com
look for
fidanza flywheel
Get that
Its 8lbs less than stock
i got mine for 350 dollars on there once
OR... go to the group buy forum and see if SR will organize a group buy
[ September 10, 2002, 02:32 PM: Message edited by: JAWS 021 ]
Old Sep 10, 2002 | 07:37 AM
thanks man for the help with the fly wheel. what other bolts ons do u think i should worry about befor the clutch. the onjly reason om doing the clutch now is because its going out and i figured i might as well do a better system now because im going to be doing more stuff in the future.
Old Sep 10, 2002 | 07:59 AM
A stage 1 clutch should do just fine. It should be good for 50% to 70% more power over stock.
That's over 200 Hp. The stage2 is probably going to be overkill unless you add Nitrous.
Old Sep 10, 2002 | 11:32 AM
Fast.Type-S's Avatar
Now onto my car: With I/H/E/1.8 cam, CAI, apex-i N1 exhaust riding on 2.5 inch exhaust, hi-flow car sound CAT, 4-1 headers, BBTB and BIM...which clutch shoul I get? Link's welcome. Oh, im a daily driver. T/SC/Zex more than likely never hit my car (hard to say..but $$$) And some overall (with install chrages and time) $$$ amount's/times. Who can do the install? Pepboy's type places or REAL garage or dealership?
THANK YOU kindly. (As i can no longer race..and I feel slow)
Oh, I have white wiper nozzle light's...dont forget to account for those tongue.gif
[ September 10, 2002, 06:34 PM: Message edited by: Fast.Shark ]
Old Sep 10, 2002 | 11:54 AM
Xerro's Avatar
Fast.Shark:
MAN!!! For those nozzle lights you're gonna have to go like Stage 6. J/K LOL. There's also a place called Clutchnet.com. The clutch won't be listed but you can call and get one. On the flywheels does anyone know if that Fiaza...fianza...or anyone else make a light-weight flywheel for the 2k2 Accent?
[ September 10, 2002, 06:55 PM: Message edited by: Xerro ]
