updated talon shifter will work
Old Sep 15, 2002 | 01:14 PM
XtremePc's Avatar
Default updated talon shifter will work
i was at local pick and pull and noticed a talon
shifter console was gone and it looked a lot like ours but the throws are shorter and the shaft is shorter
what do you think
[ September 17, 2002, 08:23 PM: Message edited by: XtremePc ]
Old Sep 15, 2002 | 05:08 PM
JAWS 021's Avatar
eek! eek! eek!
its the PCextreme short shifter
eek! eek! eek!
looks very similar
[ September 16, 2002, 12:47 AM: Message edited by: JAWS 021 ]
Old Sep 16, 2002 | 01:27 AM
Solo-Baric's Avatar
the worst could happen is that it wouldn't work. i'd try it. because i looks like it would fit. besides it only takes 10 mins at the most to swap them out.
Old Sep 16, 2002 | 03:16 AM
KSpec's Avatar
No, they are opposite...it looks like it would work but the cable needs to be hooked up on the left side, that one looks like it connects on the right.
Old Sep 17, 2002 | 10:54 AM
NightRaven's Avatar
HE-MAN:
Umm the mounts on that shifter mount on the left. look at the mounting bracket the left side of the photo has the holes for the cables to route through which then in turn attach on the left. looks almost exactly like ours. not 100% sure without measuring it.
Old Sep 17, 2002 | 01:33 PM
XtremePc's Avatar
ok i put it in and let me tell you short throw
very short take's more effort to shift thats for sure
new bolt hole's had to be drilled
but it will defintitly work
and i only paid 10 bucks fot it
Old Sep 17, 2002 | 02:19 PM
KayJai's Avatar
Cool beans man!
That's good to know
I'm guessing the shifter has the same thread pattern as ours, so you can put the OEM knob on?
Old Sep 17, 2002 | 02:23 PM
J@WS 01's Avatar
What year Talons/Eclipse/Lasers?
Old Sep 17, 2002 | 02:25 PM
KSpec's Avatar
Oh, right, I was looking at it from the wrong perspective...my bad. Hey...that's cool!
Old Sep 17, 2002 | 03:05 PM
XtremePc's Avatar
J@WS 01:
91 to 94 seems to be the better of them shorter throw
thats the one i got out of a 94 talon
LINKY
[ September 17, 2002, 10:06 PM: Message edited by: XtremePc ]
