Log in
View Full Version : Transmission, Clutches, Shifters
Pages : 1 2 [3]
  1. Clutch release cylinder ??
  2. transmissions - I was bored
  3. 6speed box on a 2k Tib?
  4. hyundai clutches
  5. flywheel pros and cons
  6. Transaxle area (Manual)
  7. Flywheel Benefits
  8. Clutch/Flywheel Install
  9. which stage clutch 2or3
  10. performance clutch
  11. clutch or gearbox?
  12. Auto Tranny Question
  13. Clutchmasters flywheel
  14. damn tranny...help!!
  15. Stock Clutch Limits
  16. rev limiter on auto?
  17. homemade short shifter
  18. How long do aftermarket clutches last?
  19. Clutch Pedal Noise
  20. Clutch DIY?
  21. Tranny Problems.......
  22. Turning Flywheel?
  23. time to change clutch?
  24. I need a clutch?
  25. i have a tranny cooler?
  26. Flywheel/clutch prob
  27. engine/tranny rebuild, S-AFC didnt ruin waranty
  28. Problems installing a SR shifter kit in my 2000 Elantrar
  29. Flywheel Bolts
  30. Tranny Fluid
  31. strut bar installation & short shifter installation question?
  32. Lighten Flywheel and S/c
  33. B&M Shifter.... Ooooohhhhhhhh GOD yes!
  34. Clutch!
  35. 2003 Tibby! 5-speed/6-speed?
  36. Flywheel Question
  37. Installing Clutch
  38. Clutch
  39. Trans Swap
  40. Clutch Feels Funny?
  41. Clutch
  42. clutch model number
  43. Tranny Slippin!!!
  44. 5-Speed REBUILD
  45. tranny
  46. Red, Random... Drag Transmissions?
  47. Clutch or not?
  48. Missing parts on Tranny!?!?
  49. clutches
  50. stage3 or 4 clutch?
  51. short shifter installation
  52. Fidanza Flywheel update
  53. short shifter
  54. Short Shifter for Accent
  55. Limited Slip
  56. Auto tranny makes more torque than stick shift?
  57. Clutch going out?
  58. changing from auto to manual tranny
  59. Tranny cooler install
  60. Clutch Change
  61. Aluminum Flywheel, and clutch....
  62. Tranny Swap
  63. Clutch, stage 1 stage 2 stage 3 oh my!
  64. complete clutch?
  65. Performance Clutch
  66. Performance Brakes & Clutch
  67. Clutch Options
  68. 2.0 vs 1.8 tranny
  69. 6sp tranny
  70. 3500 RPM = 70Mph
  71. Cold Air Intake for Automatic tranny
  72. short shifter
  73. shifttronic
  74. SR Type-R Shifter
  75. Double Clutching
  76. Tibby vs elantra Trany
  77. problem with rev limiter
  78. Low to mild clutch
  79. **Possible** group buy on BETA Quaife differentials
  80. Quaiffe now seriously considering diffs!
  81. What about a shortened shifter for a 2K Tibby?
  82. Clutch Install?
  83. B&M Short Shifter
  84. Limited slip diff...
  85. transmission problems
  86. clutch upgrade
  87. Light weight flywheel?
  88. clutch prob..please help!!
  89. HELP! SR ShortShifter
  90. Engine/Tranny Problem update
  91. Help needed urgently with tranny/clutch problem
  92. tire slippage
  93. Clutch whistling again !!!
  94. Clutch thoughts....
  95. hve shortshifter
  96. Reverse Problems
  97. Clutch Slippage?
  98. ShortShifter Installation??
  99. ShortShifter Anyone??
  100. Lightened Flywheel
  101. throwout bearing wearin out :(
  102. Limited Slip Differential
  103. Brake into clutch
  104. clutch question??
  105. short shifter
  106. RPM??
  107. HELP!! Transmission Problems?
  108. Clutch???
  109. Aftermarket clutch?????
