stage3 or 4 clutch?
Old Mar 7, 2002 | 03:00 AM
white-shark's Avatar
Default stage3 or 4 clutch?
Hi guys, I donīt know which stage to buy, because I have turbo in my tiburon , but I also drive everyday my car . I also want to buy the flywheel of HDK. it is good??? very good price? anybody what can help me? thanks!
Old Mar 7, 2002 | 03:21 AM
JAWS 021's Avatar
call hdk and make sure they have it,... if they dont have it in stock prepare to wait like a month or so to get it.
As far on how good it is,... i have no clue
I think a stage 3 clutch would be good enough
Old Mar 7, 2002 | 05:00 AM
onpol's Avatar
Buy the 4 in case you want to raise the HP later.
Old Mar 7, 2002 | 02:21 PM
thanks, guys!!!!!
Old Mar 7, 2002 | 02:38 PM
If you are going to stay N/A go with the Stage 2. If you plan on going with a low power turbo setup (under 250 Wheel HP) then a stage 3 would be the way to go. If you plan on going with a crazy power setup (over 250 wheel HP) then a stage 3 or stage 4 would be the way to go.
There is also several clutch choices from www.hve.com.au www.rpw.com.au
