Flywheel/clutch prob
Old May 11, 2002 | 05:28 AM
shagn_wagon's Avatar
Default Flywheel/clutch prob
hey guy's... The past couple of days I have noticed this mean sounding sound commin from my engine, sounds like two peices of metal sandpaper rubbin together and it makes the sound when i push the clutch in. Im thinkin either the flywheel or clutch or even a bearing is screwed up. I might go ahead and get a new clutch.. anybody who has had this happen how much is it for a new clutch. and would it be cheaper to get an aftermarket clutch instead? thanks guy's
Bryan
Old May 11, 2002 | 12:28 PM
MechaniX_034's Avatar
Vehicle: Lancer Evo IX
Hey bro do you feel like the clutch pedal is viabrating when you push it in, and is the engagement point really high on the clutch pedal throw? If so then it's propably a clutch problem.
Check for the problem before making any plans man...that way you can budget correctly!
Old May 11, 2002 | 08:22 PM
thanks for the advice.. but i was gettin ready to leave home today and bam.. the clutch died ): so im gonna go to the dealership monday and see how much itll cost.. thanks though!~
Bryan
Old May 11, 2002 | 11:55 PM
Geeez...sorry to hear that man! Good luck with it ok?
