Clutch???
Old May 13, 2001 | 06:14 AM
RdWhteblur's Avatar
Default Clutch???
Im also wondering which type of racing clutch would best suit my tiburon?
i was told that it was bad to get a mettalic clutch especially if it floods alot where u live, also its bad to get a clutch with no teeth on it because all the power can be transferred to your transmission hich can be bad, please help im lost?????????
Old May 13, 2001 | 04:18 PM
The type of clutch to get depends on your driving style and HP.
Is the car going to be a daily driver? How much HP do you currently put down, and what is your projected HP goal?
Old May 14, 2001 | 02:03 AM
RdWhteblur's Avatar
Well yes my car is a daily driver, im currently runnig at 160 hp with just bolt ons, but im adding cams, a BBTB, and a header
I want to get as much hp out of my car before I actually turbo charge it. My current clutch is slipping when i get on it from the start, so instead of replcing it with a stock one I want a performance clutch.
Old May 14, 2001 | 02:52 AM
Go here
http://www.teamsr.org/cgi-bin/ultimatebb.c...c&f=16&t=000029
