problem with rev limiter
Old Dec 29, 2001 | 10:51 AM
arn's Avatar
arn
Default problem with rev limiter
I'm putting a ZEX kit on my 01 Tib. I'm just thinking about the rev limiter. Had anyone have a problem with it when you use the nos? When is the best time to use NOS?
Since ZEX only work when ur WOT, can u arm it whenever?
Old Dec 30, 2001 | 01:07 PM
You should install a window switch for the Nitrous. It will kick in the nitrous at 3000 RPM and kill it at 6400 RPM. This will keep you from blowing your tranny or clutch by spraying too soon, and keep you from over-reving the engine by spraying too long/too late.
Old Jan 1, 2002 | 04:28 AM
NOSdUpTibby21's Avatar
Vehicle: 2000 Tiburon
Window switch?? How do you do that??
I have gotten away with laying off the pedal just a fraction of an inch so the NOS stops spraying about 500 RPM's before hitting the limiter, try that.
Old Jan 1, 2002 | 05:27 AM
you can get nitrous controlers or window switches from www.summitracing.com
If you forget to lift the pedal, or if you miss time it...you can damage your engine quite easily...
[ January 01, 2002: Message edited by: Random ]
