Transaxle area (Manual)
Old Jun 10, 2002 | 07:18 AM
alz99's Avatar
Vehicle: FX Coupe
Default Transaxle area (Manual)
hay people..
Well i have to take my gearbox out which is gona cost a bit.
So here's my Q.
What can be upgraded around this area i have a 55 shot and some pistons to install aswell.
I was thinking.
Clutch - HVE Heavy duty
Fly wheel
Any thing else?
Cheers for the info...
Old Jun 10, 2002 | 09:37 PM
MechaniX_034's Avatar
Vehicle: Lancer Evo IX
Driveshafts...
Old Jun 11, 2002 | 01:21 AM
for a 75 shot of Nitrous, the stock driveshafts should be fine.
Adding a Kazz or Quaife Limited Slip Differential (LSD) would help.
If you want to go all out, you can change gears and final drive ratios. You can either reuse stock parts from various different beta trannies, or order in gearsets from Korea.
Old Jun 11, 2002 | 04:52 AM
JonGTR's Avatar
Here's everything you need for your h.p. range. See my post here: http://www.teamsr.org/UBB/ultimatebb.php?u...c;f=16;t=002397
Old Jun 11, 2002 | 06:33 AM
alz99's Avatar
Vehicle: FX Coupe
cheers for the info guys!!
has anyone tried any of these parts and do any Australian companies make flywheels for the 97 tib..?
I wonder!
Old Jun 11, 2002 | 09:37 PM
Do a forums search man, this has already been discussed. Good thing about dead threads, they're a wealth of information!
