clutches
Old Mar 12, 2002 | 07:14 AM
Raverboy's Avatar
Default clutches
hey i got a question...i was thinking of getting a new clutch and i noticed that there is a stage 2 and stage 3 clutches...what is the difference??
Old Mar 12, 2002 | 07:15 AM
JAWS 021's Avatar
The difference is in how much power they can hold.
A stage 2 is good up to about 200WHP, a stage 3 is good up to about 250-300WHP
Old Mar 12, 2002 | 10:51 AM
Cheuk in Seoul's Avatar
Which clutches are you talking about.
We have used a Stage 3 clutch from a well known US company and it will just bearly hold 200 wheel hp.
Old Mar 12, 2002 | 12:45 PM
Raverboy's Avatar
so basically its all about how much HP your cars got?
Old Mar 12, 2002 | 12:58 PM
skierd's Avatar
Vehicle: 1997 accent L
i think he means KORE's cheuk.
Old Mar 13, 2002 | 02:14 AM
Zman's Avatar
Just for informative purposes, how many HP's would be the limit for a standard (OEM I mean) Tiburon/Elantra clutch?
And, are there any differences in regards driveability when you change OEM clutch to a more performance clutch?
Old Mar 13, 2002 | 02:43 AM
JAWS 021's Avatar
Cheuk in Seoul:
sorry sir,... i thought it was just in general
BTW what company was that??? Im going to need a new clutch REAL soon since mine is slipping.
BTW when does the stock clutch start giving out???
Old Mar 13, 2002 | 12:19 PM
Zman- The cluches "holding" power varies by gear (torque to the wheels) and how you treat your clutch. Driven perfectly, the stocker might hold to 150 to the wheels. In most peoples car, it wears out from abuse. Either heat glazing from too much slipping, or breakage/fraying from too severe of engagement.
The higher the HP potential of the clutch, the "grippier" it is, thus the harder it is to drive unless you shift/clutch very well. I would only reccomend a stage 2 for N/A or light nitrous setups and a stage 3 for supercharger/turbo/heavy nitrous.
