Gearbox linkage / slack removal
Old Mar 30, 2003 | 12:15 AM
Jon's Avatar
Jon
Default Gearbox linkage / slack removal
Right then at last I’ve put together a little description and a few pics of what I did to take up the slack in the gear linkage. This is so simple to do but its amazing how much better it makes the gear change feel. The first pic shows the bad points and the bolts and pin that need to be removed to get the linkage out. In the first pic it shows the washer and dowel/sleeve already fitted.
First off you need to remove the two bracket bolts and the R pin to make life easier, then you should be able to lift the whole lot away from the gear box with it only being attached to the cable still.
As you can see in the above pic there is a gap at the side of the rubber grommet and the right hand linkage. These linkages are only supposed to move up and down but as there is a large amount of free play when they move, they also move from side to side. I would say this is one of the reasons why our gearboxes don’t locate smoothly as well as the excess slack in the stick. Once you have it like this the left hand part will just slide off leaving you with this.
For the first bad point it is as easy as putting a washer on the right side of the grommet when you reassemble. Or if you have the same problem as Shaddoh had, where his grommet was split and worn he just removed it and replaced the whole lot with 2 washers. The second bad point seems to vary from year model. We are not sure if this is what Hyundai did when they made the gears a bit better after 2000. The top peg on the left is the part that locates into the gear box main shaft. This peg locates between two lips to move it up and down. However on mine there was a massive amount of difference in the size of the peg and the gap between the lips. Translating to lots of free play in the stick. So all I did was to get a piece of steel bar with an 8mm internal bore and turn it down to the correct size to remove the slack. On Shaddoh’s linkages there was a plastic button on the end of this peg so he didn’t need to do this part. But if yours hasn’t or is worn this will remove a lot of free play and will last a lot longer than the plastic.
Then all that is left to do is reassemble the linkages back together ( not forgetting to add the washer). It’s as simple as that, even if you have the plastic button on yours and it is fine, it is still worth doing. As I said Shaddoh had the button on his but he still felt a lot of difference just by putting the washer in there.
There is another mod that shaddoh made to the linkages on the stick side but I will leave him to post an explanation on this. I hope this helps as it is worth doing.
Old Mar 30, 2003 | 06:13 AM
ONLY1DB's Avatar
heres a good question...what size washer did you use??
Old Mar 31, 2003 | 01:57 PM
coupe2k's Avatar
Awesome, thanks! Gonna try this on the weekend.
Old Mar 31, 2003 | 04:56 PM
turbulence's Avatar
grate job!!! i'm sure many of us on the board will forever thank you for a simple mod like this. bow_down
Old Mar 31, 2003 | 08:46 PM
ONLY1DB's Avatar
i guess you can use any washer??? does size matter?? *L* dunno
Old Apr 1, 2003 | 12:55 AM
Kevdog's Avatar
It seems the washer should match the size of the rubber grommet. The thickness should be enough to take out the slack of the connection smile.gif
Still trying to figure out a way to do this for those of us without a machine shop handy
Old Apr 1, 2003 | 04:26 AM
Jon's Avatar
Jon
If you can get hold of a piece of steel bar with 8mm internal diameter its easy enought just to file it down. It doesnt have to be perfectly round you can even make it square, as all it has to do is remove the gap between the two lips and as these are flat then square will do fine.
To be honest i didnt note the size of the washer but as Kevdog said as long as it fits over the rod and is roughly the same size as the rubber grommit it will be fine, as you are only aiming to remove the sideways play. Mine was about 10mm internal 24mm external and 2mm thick. I just went through an assortment untill i found one that fitted best.
Old Apr 1, 2003 | 06:47 AM
ONLY1DB's Avatar
thats the anwser i was looking for...i cant stand this trial and error bs....sorry....thanks for the anwser. oh yeah...good find!!
Old Mar 26, 2013 | 01:28 PM
hcriddick21's Avatar
Vehicle: 1997/Hyundai/Tiburon RD1
Anyone got this saved on their computer? In the DIY section we should try to get all the pictures back up.
Old Mar 26, 2013 | 01:58 PM
StrikeEagle's Avatar
holytenyearoldthreadbatman!!!
