Are there any clutches from other cars that would fit ours?
Old Mar 26, 2013 | 12:58 PM
conscience's Avatar
Vehicle: 2001 Tiburon
Default Are there any clutches from other cars that would fit ours?
Would say a factory clutch from a WRX, Evo, Cobalt SS, or SRT-4 fit in a Tiburon or Genesis or Accent? Actually, has anybody ever even compared clutches side by side from other cars to what we all have? I guess one could always google image search and see what the clutches look like but no one would ever know if they fit without doing a real time installation with multiple types of clutches unless you worked at a tranny shop I suppose.
Old Mar 27, 2013 | 08:04 AM
tibbytib's Avatar
I'm currently using a Mitsubishi eclipse clutch (non Turbo) with a pull to push clutch conversion in my Beta II. So far I love it and have no more worries of the throw out bearing "pulling" out and leaving me stranded.
Someone else chime in, is it a pull style clutch in both the beta I & II transmissions?
Old Mar 27, 2013 | 08:11 AM
yes pull in both transmissions
clutches require a hell of a lot more than "look the same"
spline count, hub spacing, bolt pattern, bearing location, physical size etc
Old Mar 27, 2013 | 08:35 AM
A couple of people have said the factory Evo clutches fit on a Gen Coupe but theres no proof yet.
Old Mar 27, 2013 | 11:30 AM
pas1216's Avatar
Vehicle: 1991 Impulse RS
is there not enough companies making aftermarket clutches for the Genesis??? What would be the benefits of running an EVO clutch over a performance clutch made for the Genesis?
Old Mar 27, 2013 | 12:44 PM
Much cheaper. You find someone who is selling their barely used OEM Evo clutch because they needed an aftermarket one to handle more power and you walk away with something thats half (or more) the price of an aftermarket Gen Coupe clutch.
Old Mar 27, 2013 | 09:49 PM
wheel_of_steel's Avatar
Dunno about buying a used clutch mayne, especially from an awd car
