odd oil question
Old Sep 12, 2012 | 02:46 PM
zero_gravity's Avatar
Vehicle: 2004 Hyundai Accent
Default odd oil question
hello everyone! been a while since i've posted...have an odd question.
the quick version: 2004 accent, manual trans. normal oil is 75W-90 GL-4. anyone see any problem with topping up with 80W-90? we're talking a couple ounces here.
the long version (bit of ranting): replacing a CV boot tomorrow, that means draining my trans oil. currently have 75W-90 dino oil in there. i am not interested in going synthetic, as some of you might remember although it was amsoil i'm pretty sure that trashed my last transmission and also caused some slight problem with synchros meshing on 3rd gear in my 'new' one. switching to the conventional fixed the issue. so in short, i know most of you have used synthetic and had wonderful results. i'm still not using it, don't care.
so i started a quest to find some regular 75W-90 gear oil....i went to EVERY f*cking store in the city. NOBODY has this. its either GL-5, completely the wrong oil weight, or synthetic (see above). even the DEALER didn't have any to sell. they only have a drum of it in the shop and wouldn't share. bastards. so now i'm forced to reuse this oil (it should be in good shape, was about a year ago it was done) and then i will need to top up anything lost.
only oil i can find is a crap motomaster generic 80W-90 that apparently meets GL-4, 5, and every other spec known to man and may even be suitable for chuck norris to lube his wife up with.
so provided that there is no problem with the oil in the trans when i drain it, we're talking an ounce or two to top it up. i can't see this causing me any trouble. anyone disagree?
thanks guys.
Old Sep 12, 2012 | 05:09 PM
pas1216's Avatar
Vehicle: 1991 Impulse RS
I wouldn't really see any problem in running the trans full of 80w90 as long as it's GL4 approved. The only difference is it's a bit thicker/heavier of an oil.
You seriously can't find ANY GL4 75w90!? Did you try walmart or parts pro (the canadian tire auto parts only store)?
Old Sep 12, 2012 | 08:06 PM
yeah can't find any that is non synthetic. partsource, two CT stores, walmart, carquest, napa, ideal supply (local machine shop/parts store), and finally the dealer. its f*cking bullshit man.
as far as i understand going from 75W to 80W just means that it will be a tad thicker when its cold. i'm more asking how sensitive these things are. from my experience they are rather touchy, but i maintain my accent was built on a friday.
Old Sep 12, 2012 | 08:19 PM
Order some Redline MT-90 GL4 for the next oil change. For this one, you'll be fine on 80W especially if you go easy on it.
Old Sep 13, 2012 | 09:55 AM
even though i already said i'm not interested in synthetic, i knew someone would suggest it anyhow.
thanks for the confirmation on 80W at least. i can't see it being trouble, just wanted to see if anyone else sees a problem with it that i'm not.
Old Sep 13, 2012 | 08:16 PM
All synthetics are NOT the same, and rejecting them all because you picked the wrong one is foolish. Redline MT90 is THE best for Hyundai transaxles. Next would be the OEM fluid which is actually pretty good. One would hope it would be good, because they guarantee the gearbox will last you at least 100,000 miles when OEM fluid is changed at the appropriate intervals!
Old Sep 13, 2012 | 08:22 PM
dealers are put to discretion when it comes to gear oil
as long as its rated at the proper ratings
i worked at 3 different hyundai dealers, none use "hyundai" oil for anything other than auto transmissions
pennzoil, valvoline, kendall
Old Sep 14, 2012 | 07:33 AM
since you seem to have forgotten, until you buy it off me its my car to be foolish with. my car will not have synthetic in the gearbox. period. i already stated that but seems i need to again.
and sorry if i don't have faith with synthetic in this gearbox. picked a 75W-90 GL-4, exact spec. how is that the wrong one? oh just wasn't redline, sh*t how stupid of me! result: destroyed transmission, synchro grinding on 3rd AFTER the second one was rebuilt. so no i'm really not interested. a different/better trans one day sure, i'll give it a try.
now how about locking this thread before things get any more stupid?
Old Sep 14, 2012 | 09:11 AM
OTECTom's Avatar
You spelled Stocker wrong
Old Sep 14, 2012 | 01:22 PM
Maxpow's Avatar
Vehicle: 2002 Hyundai Accent, 2007 Kia Spectra
So uh, have you tried synthetic?
