dropping the trans
Old Feb 17, 2013 | 02:58 AM
98x3beta's Avatar
Vehicle: 1998/Hyundai/accent
Default dropping the trans
Question...first time dropping a trans an im kinda stuck..what bolts are suposed to be taken out on the trans mount.
Details: x3 beta 1 accent trans.
Old Feb 17, 2013 | 04:36 AM
wheel_of_steel's Avatar
There are four bolts holding the trans mount to the driver's chassis rail. Take the FL wheel off, and pop off the four rubber grommets inboard and fore of the strut. You'll be able to get at the bolts from there, but be careful not to drop em inside the chassis on the way out.
Old Feb 17, 2013 | 05:14 AM
98x3beta's Avatar
Ok i remember those bolts when i was building the car lol but i didnt know if it was nessacary for me to take them off again for the trans but ok thats alot.! I will post more if im having issues
Old Feb 17, 2013 | 04:36 PM
WytchDctr's Avatar
Vehicle: 14 EGT 2.0
I am pretty sure one of those bolts is still inside my XD. I dropped one and there was no hope of getting it back from where it fell/wedged. Magnets were no help either... :-/ At least it doesn't rattle from there?
Old Feb 18, 2013 | 02:25 AM
98x3beta's Avatar
I dropped the tranny Successfully my whole reason for this is because im getting rid of the car and starting over to a cleaner shell. But i have a question. Will the motor stay put on just the passenger mother mount? Without the jack there?
Old Feb 18, 2013 | 07:35 PM
If the lower brace (with the lower roll stops/engine mounts) is out, the engine will fall with just the passenger side mount holding it. If there is an old tire under there, or two, or a stack of 2x4s or something, it should be fine if you don't move the car. If you have to move the car, rig up a brace.
Old Feb 18, 2013 | 07:45 PM
98x3beta's Avatar
Ok
