Shifter bushings
dremel down the outside cage on a skateboard/rollerblade bearing-... you'll have to add washers/rubber grommets as needed.
i think a 1" hole saw through a nice piece of plastic does the trick aswell
I ground out the insides of the ends of the shifter cables to make intact skate wheel bearings fit . . . but "where to get them" any skate shop will have a pile of used old bearings free. pick a couple that roll fairly smooth.
