Transmission Installation Trouble, Snap Ring Trouble, Please Help
Old Mar 18, 2013 | 08:59 PM
Megladon's Avatar
Vehicle: Tiburon
Default Transmission Installation Trouble, Snap Ring Trouble, Please Help
I was doing a clutch job on my 98 shark and as I reached for a bolt to screw on the bell housing the trans falls on its side and cracks what I believe is the reverse connector.....
if that wasnt bad enough i try to align the trans on again and notice that it wasnt aligning on the dowel pins as it should. So I looked at the pressure plate and noticed that the snap ring on the pp had broken off its lil bracket and was hanging in the middle. This is a brand new valeo clutch any suggestions as to replace the snap ring??
Old Mar 18, 2013 | 09:25 PM
Megladon, you are more likely to get the help you need and less likely to cause confusion if you start your own thread for a new problem.
I don't know where to get a new snap-ring, but my first guess would be to contact Valeo and see if they can get one to you.
Old Mar 19, 2013 | 02:57 AM
wheel_of_steel's Avatar
The reverse light switch can be unscrewed and replaced for not much money. Do replace it though, I left a cracked one on my trans and ended up with milky, non-lubricating oil within a thousand kays.
Old Mar 19, 2013 | 09:28 AM
did you snap the throwout bearing directly to the pressure plate prior to putting on the trans? if so that's your issue.
you can get a new bearing from anywhere, valeo made the oem clutch so I'm certain you can just order a oem bearing and be fine
so to reiterate the install goes plate and disk bolted to the flywheel, bearing on the fork (don't grease the bearing as so many before you have) then put it on the dowels and move the clutch fork arm until the bearing snaps into the plate
