Clutch help!!!
Old May 13, 2011 | 02:45 PM
97dsscobra's Avatar
Vehicle: accent
Default Clutch help!!!
I put a 1.8 elantra motor on my accent with the stock accent trans.. Problem is I'm using a mirage clutch nd I've gone through 2 new clutches in less than a month.. Which clutch am I supposed to use for that setup?? Or a certain flywheel??
Old May 13, 2011 | 04:42 PM
WytchDctr's Avatar
Vehicle: 14 EGT 2.0
accent. Why did you go with the mirage?
Old May 14, 2011 | 07:59 AM
97dsscobra's Avatar
Vehicle: accent
the mirage clutch worked on a 2.0 beta with the accent trans so I figured it would with the 1.8
