11 elantra manual
Old Feb 18, 2011 | 07:09 PM
WytchDctr's Avatar
Vehicle: 14 EGT 2.0
Default 11 elantra manual
If you do let me know, Id like to see if it has the sonata's herpderp cut throttle piss me off kill switch of piss if you shift at high rpm. Thanks
Old Feb 18, 2011 | 07:32 PM
tanc's Avatar
Vehicle: 1997 Tiburon
I've driven quite a few, not entirely sure what your description means.
Old Feb 18, 2011 | 08:32 PM
WytchDctr's Avatar
Vehicle: 14 EGT 2.0
you have driven a few brand new 6spd elantras?
Drive a new sonata and shift at high rpm and it does this cut throttle annoying crap to protect the transmission thing. Wont buy something that does that.
Old Feb 19, 2011 | 12:12 AM
tanc's Avatar
Yes, 2011 Elantra's and Sonata's. The gas pedal is electronic so you can't flat shift it. Throttle will always close on shift.
If that's not what your referring too, than you need a bit more clarification.
