Cold weather rev limiter
Old Feb 16, 2012 | 01:02 PM
NJ_DRIVER's Avatar
Vehicle: 2004 Tib I4
Default Cold weather rev limiter
Can cold weather cause your rev limiter to be lower? I’ve heard stories that it can, but if its electronically controlled by the ecu, how is that possible?
Old Feb 18, 2012 | 05:27 PM
krazytib's Avatar
I doubt that. How is this tested? Free revving while stopped or is this seen at full throttle shifts? Automatic or manual transmission?
I guess if it's really cold out and the car isn't up to proper operating temperature then the car might be cutting back on performance since its thinks it still in warm up mode.
Old Feb 18, 2012 | 06:13 PM
Red Raspberry's Avatar
It may. The Gen Coupe won't allow full boost when oil temp is low.
