Stiff clutch
Old Feb 24, 2012 | 11:33 AM
Angelos's Avatar
Vehicle: 01 Tiburon
Default Stiff clutch
I have noticed that once in awhile when I get in the car, my clutch seems a little stiff. After using it a few times, it loosens up and is fine. It doesn’t do it all the time, just maybe once every two or three weeks. There no slippage and the car goes into gear fine. Anyone have a suggestion for it?
Old Feb 24, 2012 | 10:24 PM
When did you last change the fluid?
Old Feb 25, 2012 | 01:08 AM
wheel_of_steel's Avatar
Throw some lube into the pedal bushing for good measure.
