Stall converter?
Old Apr 29, 2014 | 04:58 PM
angel's Avatar
Vehicle: 00 tiburon
Default Stall converter?
Anyone know if there is a higher stall / torque converter for a 2000 tiburon?
I have a bigger throttle body, aem intake, 4-2-1 header, high flow cat, and an easy flow muffler. It runs nice but it's an automatic and acts like a slug off the line. Any cures for this? I think a higher stall converter will help. If not I may look into getting rid of the auto and see if my dads business (8 man mechanic shop with 7 bays) can put in a 5 speed.
Old Apr 29, 2014 | 08:09 PM
2000J25SP's Avatar
Vehicle: 2000 Hyundai Elantra GLS
Don't think anyone makes one, It'd probably have to be custom made. The 5 speed swap would certainly be more fun.
Old Apr 30, 2014 | 03:02 AM
XGODZX's Avatar
Vehicle: 1999 Elantra GLS Sportswagon
I found these guys when looking to do some thing with my elantra auto as they are essentially mitsu trannys anyways http://www.importperformancetrans.co...rts.-66-1.html
Being down under i got a local tranny mob to rebuild mine and put a shift kit and tweak the torque converter to a more stall
Old Apr 30, 2014 | 09:20 PM
+1 for manual conversion. You're wasting power for the convenience of letting a computer shift for you.
Old May 2, 2014 | 04:39 AM
Tibbi's Avatar
No matter how much you mod the auto, eventually the end bearing will shatter and you'll be miserable.
5 speed swap
