Starting to get some clutch chatter
Old Jun 30, 2011 | 12:56 PM
Nitrox's Avatar
Vehicle: 2003 Tiburon
Default Starting to get some clutch chatter
Ive had my aftermarket clutch installed for a little over a year and Ive had no problems. Ive recently started to hear some chatter and was wondering does this mean theres something wrong with the clutch, flywheel, or both? I ask because it just started out of no where and I dont really beat on the clutch (no high rpm clutch drops).
Old Jun 30, 2011 | 01:38 PM
WytchDctr's Avatar
Vehicle: 14 EGT 2.0
What type of clutch did you get?
Did you resurface the flywheel?
Old Aug 21, 2011 | 11:29 PM
bigfishmoney's Avatar
i would suspect bad motor mounts initially then continue with the process of elmination starting with how it was reassmbled...who really knows though good luck
Old Aug 21, 2011 | 11:35 PM
Turboron_99's Avatar
Vehicle: 13 Gen Coupe Ult.
Clutchs chatter, it is normal, if the clutch is operating smoothly no binding a popping, then it is fine, my clutch has chatter sense day one, it is extremely noticable with aftermarket performance type Discs and flywheels....
