Starting to get some clutch chatter
Ive had my aftermarket clutch installed for a little over a year and Ive had no problems. Ive recently started to hear some chatter and was wondering does this mean theres something wrong with the clutch, flywheel, or both? I ask because it just started out of no where and I dont really beat on the clutch (no high rpm clutch drops).
What type of clutch did you get?
Did you resurface the flywheel? |
i would suspect bad motor mounts initially then continue with the process of elmination starting with how it was reassmbled...who really knows though good luck
Clutchs chatter, it is normal, if the clutch is operating smoothly no binding a popping, then it is fine, my clutch has chatter sense day one, it is extremely noticable with aftermarket performance type Discs and flywheels....
