what are the consequences of driving on a bad throwout bearing?
Old Oct 31, 2012 | 05:18 PM
theman's Avatar
Vehicle: 2004 elantra
Default what are the consequences of driving on a bad throwout bearing?
discuss
Old Oct 31, 2012 | 05:28 PM
HotBlue02's Avatar
Vehicle: 02 Hyundai Accent
a worse throw out bearing
Old Nov 1, 2012 | 08:03 PM
^ exactly that. The only problem is, eventually it turns into a used-to-be-a-throwout-bearing chunk of metal spinning uselessly in place, so . . . replace it when you can. A little eekeekeekeekeekeekeekeek has been known to go on for quite a while. Failure to work the clutch can't really be tolerated for very long.
Old Nov 3, 2012 | 11:22 AM
SpoolinShark's Avatar
Vehicle: 2010 Hyundai Accent
Well from my experience, I changed my clutch one time but used the same TOB and after awhile it seized up and ended up ripping out the splines on my ACT 6-puc clutch. Center of that thing was as smooth as a baby's bottom. Lesson to be learned, replace it
