Those of you real aggressive clutches
Old Sep 20, 2010 | 11:10 AM
tiburon423's Avatar
Vehicle: 2001 Tiburon
Default Those of you real aggressive clutches
How do you handle being in big traffic jams or stop and go traffic? Is it a major pain in the ass or do you eventually get used to it?
Old Sep 20, 2010 | 11:12 AM
push clutch
6 puck
easy pedal
i guess the guys who swap to "heavy clutches" and complain never drove a truck from the 80s with a solid hub mechanical clutch
Old Sep 20, 2010 | 09:30 PM
Turboron_99's Avatar
Vehicle: 13 Gen Coupe Ult.
^^^ That is exactly right, what you do is buy the kit to swap from a shitty pull clutch, to a push clutch... Competion Clutch makes one good for almost 500ftlbs of torque....And it is a 6 puck, i have it bolted to a Fidanz and it rocks, completely streetable traffic, highway stop lights what ever!
go here for the convertion
http://www.atelierhp.com
Old Sep 20, 2010 | 10:22 PM
Except those from the 80s. Didn't require the skill that a ceramic clutch takes. It's a fine line between a peeling out, taking off, and stalling with a ceramic clutch. Stage 3s are no freaking joke. I removed it after a month. If I HAD to have it, sure. It's just a pain in the ass to have to regulate your foot when you are only working with a sweet spot around 1 cm wide.
Old Sep 21, 2010 | 02:55 AM
Regit's Avatar
Vehicle: 2000 tib
Stage 4,4 puck,takes some getting used to, sometimes steep hills in the city suck.
Old Sep 21, 2010 | 05:39 AM
^ The Competition Clutch i got is a stack 4 but it is the best for drivability, if you want you can get teh stage 6, 4 puck race disc... lol but after they the stage 4 they run the same pressure plate, and the 4 puck will only hold alittle more just less drivablitiy... Good for drag racing, or drift.
Here is the clutch link to:
http://www.competitionclutch.com/pro...dex.php?id=300
Make sure if you do the conversion, you use a clutch from 89-94....
Any Non Turbo Dsm clutch you like,
Also be sure to toss that release bearing out, and use the one Deniss_99 supplies only!!
Old Sep 21, 2010 | 06:24 AM
sprague1420's Avatar
Vehicle: 03' hyundai tiburon 2.0L
stg 4 spec sclutch 6 puck solid hub.....
i dont mind city driving but trafic jams suck no matter what kind of car or clutch your driving haha but no i dont mind the stop and go
