Transmission problem on gen coupes
Old Jan 3, 2013 | 05:25 PM
turbotsukuba's Avatar
Vehicle: 2011 genesis
Default Transmission problem on gen coupes
Does going from an 18" wheel/stock tire size to a 20" wheel and really wide tires hurt the transmission? I had a mechanic tell me that it puts alot of extra wear and tear on the transmission and will cause it to prematurely wear out.
Old Jan 3, 2013 | 05:33 PM
No. It'll be fine.
Old Jan 3, 2013 | 09:00 PM
Unless you are talking about some cast iron wheels. The difference is likely to be <30lbs and the car won't even notice.
Going to 35" tires and hitting the rocks, THAT would be hard on the transmission.
