Shifting an auto while driving
Old Aug 12, 2012 | 04:12 PM
Tiburon-FX's Avatar
Vehicle: 99 Tiburon FX
Default Shifting an auto while driving
Interesting article
If you shift an automatic while driving, will you damage your engine?
By Mac Demere | Popular Mechanics – Thu, Aug 9, 2012 2:05 PM EDT
Here's an obvious but fundamental difference between people who learned to drive stick and those who've driven only ordinary automatics (a growing number, as traditional manuals disappear): Stick drivers are used to shifting while in motion. In an automatic, you shift only when stopped. Perhaps because of that, many drivers greet the idea of shifting while in motion with terror, fearing that they'll somehow blow up the engine or cause some awful mechanical shriek by sticking the car in neutral. Or worse, that they'll accidentally put it into reverse or park while cruising down the highway.
I'm here to tell you: Don't be afraid. After years as a driving instructor, and thanks to rental car companies that apparently lost their minds and let me loose with their vehicles, I can assure you: Your engine won't let you destroy it (at least not like this). And shifting into neutral at speed could save you from yourself.
Why Neutral Is Your Friend
Consider the occasional claims of sudden acceleration (aka unintended acceleration). Anytime the specter of out-of-control cars hits the news, and TV newsreaders are suddenly trying to furrow their Botoxed brows while talking solemnly of demon-possessed vehicles, I know there will soon be an onslaught of calls, texts, tweets, and emails awaiting my attention. My answer to those who fear their vehicle will decide on its own to play race car: "Put it in neutral."
Here's why: Government and private studies have shown that pretty much all sudden-acceleration crashes happen when the driver unintentionally presses the accelerator in the mistaken, but unshakable, belief they are pushing the brake. If you hit the brake, you'd know it: I have done hundreds of experiments—some that started above 100 mph—in which I pushed both the accelerator and brake to the floor. The vehicles came to a full, complete stop with the engine screaming wildly. The brake will easily overpower the engine in every reasonably well-maintained vehicle.
That said, throttles can stick open; I've experienced several. If the throttle is stuck and the driver fails to press hard enough on the brake, or pumps the brakes until the vacuum assist is depleted, the car may not come to a full stop.
The point: Regardless of whether your throttle is actually stuck or you're just mistakenly slamming on the gas, the answer is to put the car in neutral. If the throttle is truly stuck, shifting into neutral will prevent the car from accelerating. If you're like most sufferers of unintended acceleration—you're just aiming for the brake and missing—then the same is true. You won't be able to accelerate no matter how hard you hit the gas if the car is in neutral.
In my experience, neutral also comes in handy when you're in the passenger seat. If Grandpa mistakes the gas for the brake, moving the gear selector into neutral may prevent a crash. The ability to slow a learner's-permit-holding teen with a quick slap into neutral quells many parents' fears. (Slap the gear selector, not the teen. I know they deserve it. But don't.)
Why You Shouldn't Be Afraid of Shifting
Still, when people ask me about unintended acceleration and I say, "Put it in neutral," the response is almost always the same: "But won't that blow up the engine?" Nope. The engine's electronic limiter prevents that. Even if it didn't, would you rather total the car than damage the engine?
The person seeking my advice typically ignores my question and, panic rising, asks, "But what if it goes into reverse or park?" It won't. First, depending on your car, the shift lever won't move to the reverse or park position unless you press the physical button on the shifter. New cars with electronically controlled transmissions might not have such physical barriers, but they'll ignore your inappropriate request to park or go in reverse while you're moving. A few go into park at about one-half mile per hour.
Neither a U.S. Department of Transportation spokesman nor I could find any law that requires automakers to idiot-proof the transmission. However, no vehicle I've tested in the past 15-plus years will go into reverse with the car moving forward.
So there you go. Your engine won't blow if you shift it into neutral while in motion. And the answer to "What happens if you accidentally select reverse or park?" is either "Nothing" or "You can't."
http://autos.yahoo.com/news/if-you-s...-20120809.html
Old Aug 12, 2012 | 07:51 PM
I was all ready to rant about "sport shifting" an automatic and came away thinking the author seems to be an entirely reasonable person. That was pretty well expressed actually, but there is one exception:
When your car is ALL fly by wire, you are pretty much [deleted] if it is made to be sold in Europe, or by a company big enough to care about RoHS. The unintended acceleration of Priuses: caused in at least one case by tin whiskers, caused by lead-free tin plated electronics, caused by dumbass politicians in Europe setting policy based on junk science, caused by ignoramus voters who elected them, caused by government schooling designed to churn out worker bees instead of provide general education, caused by richass industrialists, caused by capitalism.
So the car crashes because of either idiocy or capitalism, or the illuminati. Or George Bush.
got it?
Old Aug 13, 2012 | 06:03 AM
wheel_of_steel's Avatar
People are afraid of shifting into neutral because the engine might blow up
