Push type conversion for GK V6 6spd?
Old Feb 12, 2015 | 08:46 AM
03tibe85's Avatar
Vehicle: 2003/Hyundai/Tiburon
Default Push type conversion for GK V6 6spd?
From looking at the GK v6 Speed it doesn't look too hard to convert to a push style clutch like the Beta engines. Anyone know if that has ever been done? I know the clutch fork is similar but definitely different in size.
Old Feb 12, 2015 | 12:44 PM
ScoupeLS's Avatar
Vehicle: 2003 Tiburón GT
I remember seeing on nt someone did a push conversion along with a triple plate disc clutch.
Old Feb 19, 2015 | 06:56 AM
03tibe85's Avatar
Only one I've seen done was the uber expensive and now defunct, NGM conversion that had a hydraulic TOB. Can't be that hard to do what the Beta guys are doing using OE parts..
Old Feb 19, 2015 | 09:07 AM
tibbytib's Avatar
Yeah, that did seem like a pretty easy fix when we did it. Just swap out parts, reposition slave, and BAM! Hardest part was driving to a local shop to get the sleeve tack welded in place!
