Clutch Masters Clutches...
Old Aug 17, 2010 | 07:03 AM
terjit's Avatar
Vehicle: 1999 Tiburon FX
Default Clutch Masters Clutches...
How good are these things? My clutch is starting to slip a little bit and I can get an awesome deal on these things. Since my engine is coming out for some head work next week i thought about picking it up and throwing it in along with my fidanza flywheel. If they're garbage I'll stay away and get something of better quality
Old Aug 17, 2010 | 07:12 AM
JonGTR's Avatar
They're up there on the list. Almost anything works ok on a n/a setup. Unless you have a turbo, stick with a street kit. Stage 1 or whatever.
Old Aug 17, 2010 | 02:24 PM
SR Tech's Avatar
Vehicle: 2011 Tuscon
Have a stage 2 in w/ a fidanza for 2 years now, held the N/A and holds the boost.
I'd recommend them
Old Aug 18, 2010 | 02:51 PM
Hive's Avatar
I have an FX400 clutch set with 4 puck sprung disk and I am more than happy with it. It has been proved as a very good worth for the money spent. I am pushing around 300 WHP and have no problems with sliping.
