Clutch Sticking To Floor
Old Oct 7, 2015 | 03:48 PM
LimeRockTurbo's Avatar
Vehicle: 2011 Genesis 2.0 R Spec
Default Clutch Sticking To Floor
At the track last week I tried riding the clutch a little more than normal to help reduce the spin. When I did, the clutch stuck to the floor and I was not able to switch to 2nd gear until I let off the gas and the RPM's came down. Is there anything I can do for this? I don't think the clutch is going bad. I have brought the car to the track about 5 or 6 times and the car just hit 31K miles. Im still on the factory clutch though if that means anything.
Old Oct 7, 2015 | 06:51 PM
i8acobra's Avatar
Vehicle: '14 Ford F-150
Bleed it with Motul RBF600 fluid.
