Raising redline
Vehicle: 2001 Elantra
What does one have to do to their tranny or engine in order to raise the redline a little bit on a beta? And is the redline ECU controlled or is it mostly internal stuff?
It is ECU controlled. What size engine have you got? Bigger capacity engines should not rev too high unless the have been modified to take it.
The best way is to fit an aftermarket computer, to my knowledge it is the only way. Someone may be able to correct me on this?
Why would you raise the redline? Without mods that support a longer and more consistent power band it's pointless. Not to mention hardened internal so it doesn't combust.
Stroke is to long on this engine with a torque band that is falling off fast at its stock redline. Unless you do cams, headwork, etc dont do it. Piston speeds are way to high anyway. Unless you want to throw an idiotic amount of money at it... leave that alone and focus on something else.. like better airflow/tires/clutch/etc
ECU SpeedCut^^^ What have you drove that has sped cut I mean i have driven a few Hyundai's and never ran into speed cut issues LOL!!! I can gear out extremely Easy in my RD, Never ever had Speed cut?
My non-abs XD has a ring gear on the axle that is listed as being for an "abs equipped" Hyundai. I figured that out when I swapped axles and pulled a CEL. When the light was on it seriously limited my ability to go fast, it dropped the RPM limiter to like 4k. I think those that have that extra sensor (it would be part of the abs if you have that) are probably the hyundais that have the speed limiter.
