down shift rev match?
Old May 17, 2011 | 01:45 PM
Carbonred's Avatar
Vehicle: 00 Tiburon
Default down shift rev match?
Wanna see if I got the way it goes before I try it
Cluch in
Blip throttle
Down shift
Then let out cluch?
Just checking if its correct??
Old May 17, 2011 | 04:11 PM
That is correct sir. You can shift before or while doing the blip if you prefer, the order doesn't matter IMO. Just raise the rpm's to match rpm in lower gear for your speed when you let the clutch out.
Old May 18, 2011 | 01:39 PM
StrikeEagle's Avatar
I don't consider it so much of a blip as a rev match. Put your throttle down to a point where the RPMs go up to wherever it will be matched. In other words, don't just bump the pedal and hope it hits the right point. Place your foot down an hold the throttle where it's supposed to be.
Old May 19, 2011 | 11:43 AM
^ which takes zero-point-nothing seconds, and sounds like a blip, once you get good at it.
edit: you can also let the clutch out as the engine speed drops, if you blip the throttle and the engine goes faster than you want.
Old Jun 5, 2011 | 05:58 PM
justRD's Avatar
Vehicle: 97 Hyundai Tiburon FX
Heel toe.
Old Jun 5, 2011 | 06:17 PM
ChattTownShark's Avatar
Vehicle: 2001 tibby
http://www.youtube.com/watch?v=IuoZeuSgEj4
^^ perfection
