Clutch SLIPPING
Old Dec 19, 2012 | 03:02 PM
MarianoTurbo's Avatar
Default Clutch SLIPPING
hi guys, i have an elantra XD 2001 with turbo....i did a long time ago the push type clutch convertion. I´m using an ACT who handle 430lb/ft, but when i´m going to race to full boost began slipping. I saw in other post that can be possible to install the MB1-XTG4.
https://www.hyundaiaftermarket.org/f...__hl__mb3-xtss
I want to buy it but i want to make sure that it fits and it´s not gonna be a problem. Somebody has made this modification?, what i have to do additional apart from the different bolt pattern in the flywheel?.
Thanks for help.
Old Dec 20, 2012 | 09:25 AM
Nobody knows??...anybody knows if that clutch kit is bigger than our flywheel??
Thanks for help.
