- Pulled & Rolled Fenders?
- HD Short throw shifter?
- 2012 Hyundai Elantra Coupe
- Elantra Touring (i30)
- Will Mitsubishi Evo injectors fit a beta?
- Mobile 1
- Elantra projector headlights 96-98
- 2000 Elantra wagon
- Will a 14" rim fit?
- Clogged up cat
- 2012 Hyundai Elantra To Get 58 MPG Highway?
- Elantra 98
- The HD..
- Thinking seriously about 2000-2005 Elantra GT
- Newbie with a split radiator
- TACH cluster upgrade for non GLS J2's
- Where to go for aftermarket A/C air conditioning??
- Removing the rear hyundai emblem
- 97 elantra
- Trip Computer
- Swoosh Rpm Guage HELP
- ported intake manifolds, whos got em?
- 02 Elantra throws 2nd O2 sensor code cant fix
- Compression ratio difference between 1.8 and 2.0
- 2011 Hyundai Elantra "On the Road" Pics -- 40/39 mpg hwy (manual/automatic)
- Time for a New Mod
- GC exhaust on an Elantra
- Electronic Rust Protection
- Elantra touring suspension in an Elantra gls?
- grease for slidepins
- Hello all
- 07 elantra parts for an 09?
- Extended wheel studs
- Suspension maintenance
- Eclipse GST fuel pump
- Hazard / Turn Signal Relay
- Different mirrors
- Thinking about getting a moon roof
- cold air intake for 09 elantra
- external ideas for 09 elantra SE?
- OBDII Laptop Software
- A/C Not Blowing Cold?
- '00 Elantra love...
- nc ilaws "nterior lights"
- Engine dress up kit
- 0-60?
- Injector upgrade
- Stuck Cable!
- Home Depot lip on an elantra
- For you XD owners
- is porting the throttle body on my elantra actually worth the time..
- Stud size for 02 elantra
- For the turbo guys: what do you guys do for emissions?
- Elantra GLS Fuse Issue
- the links
- Dream Christmas Present!
- Elantra Speaker Sizes
- Elantra Color Codes
- Elantra Bodykits
- Inexpensive modifications
- Elantra with NOS
- Video: Hyundai Secret Weapon?
- Little Fix For HD Intake
- Day driving light with E11 number on part ;p
- Hyundai Elantra Wing
- DTC P2231
- G/I : Evo X C/F Hood for 01-03 Elantras
- my intake idea for the HD
- Short Shifter for the 08 HD?
- custom fabbed up some eyelines for the xd
- When is it too much?
- Elantra drivers?
- Want To Be A Moderator
- K&N Filter for my 08 Elantra?
- What is the size of 97 1.6 Elantra injector?
- 2000 Elantra CAI question...
- 2000 elantra intake
- Dual Exhaust Elantra?
- 2.2l Elantra??
- Blue Elantra?
- Elantra Intakes... {power increase?}
- Elantra Lowering Springs..??
- 00' elantra kit and taillights
- OEM Elantra Muffler
- Projection lights for my '99 elantra
- 2001 elantra gls gauges
- high rpm when start my elantraGT in the cold morning
- What make the difference between the elantra 1.8L and 2.0L?
- 01 -02 Elantra GLS / GT CAI
- 00 elantra bofy kits
- A/F Guage on 01-02 Elantra??
- Fuel Rail
- 2001 Elantra timing Advance Kit ???
- Good news for Beta2 Owners (2001 Elantra and 2003 I4 Tibby)
- supercharger and intake
- Too much power for your tires? Try this
- Headers For The Elantra GT
- AEM intake for Elantra
- Quiet CAI new Tib/Elantra
- elantra/accent cams!
- Project Mitsu Elantra GSX....
- Exhaust for my Elantra!!
- Elantra ECU
- Where can i buy turbo kit for a 2001 Elantra?
- Zex Kits on a 2002 Elantra?
- 95 Elantra GLS Turbo.
- Elantra CAI
- Any dressed up 2K1+ Elantra engines?
- Elantra Pics
- CAI Help
- Elantra GT cam, negative points?
- s-afc in a 2001 elantra
- 1.8/Elantra GT Cam
- WANTED: Recipe and $$$ for 300hp+ Elantra
- how do i take off the exhaust from my 2002 elantra gls
- what can i do to make my elantra faster
- Elantra 2001 CAI
- 2002 ELANTRA INTAKE
- hi flow catalytic converter
- 97 Tiburon Strut Bar to 97 Elantra
- 500hp here I come! got fuel pump installed!
- Elantra 2002 "?"
- tip (or older elantra header) on a 99 elantra
- 2.0 in 96 - 98 elantra
- SR BBTB on 2001 Elantra is installed
- 95 Elantra Header.
- CAI for 96 Elantra
- Pic Of my bent TB and busted TPS
- Important info re; ARP studs for Tiburon/Elantra
- More questions again...
- What your guys thoughts on these two products?
- TB Spacer and coolant line
- 2001 elantra Fuel pump
- I'm not fooling around no more
- elantra/tibby tranny ?;)
- cat-back for elantra GT
- Elantra CAI
- Elantra GT cam
- 1.8/Elantra GT Cams...
- 2k elantra engine code...
- mustang vs elantra
- elantra gt cam
- 12 HP gain from CAI
- Cat-BACK exhaust on my elantra WOOO HOO
- GT Cams
- ECU upgrade & etc.
- Rich fuel problem FIXED !! READ THIS
- Torque Calculation
- CAI for auto tranny Elantra
- tachometer location HELP !
- does 99 tib exhaust fit 99 elantra?
- Elantra GT Cam
- Fuel pump 2001 elantra
- ARP studs part numbers for Tib/Elantra:
- 195 WHP Elantra
- need help with cams!
- Speed "governor" on 2002 Elantra
- elantra GT ?
- I need Elantra Indiglos
- clear corners for 2000 Elantra
- Two Seater Elantra
- I Ordered Color Gauges for my 2001 Elantra and....
- Elantra GT?
- 2001 Hyundai elantra rim size help!!!
- Elantra GT Intake Cams
- cai for elantra
- Need Help Performance Parts For Elantra 1.6L
- Elantra GT engine stuff
- Elantra Auto intake in testing
- Odd Occurance.
- Lowering srings for 02 Elantra
- elantra colors?
- Updates of lowered 2001 Elantra
- headers
- BAD NEWS !!!
- MSD Dis 2 is in !!!!!!!
- question for random
- redline
- Ignition wiring
- 17's on elantras....
- Offset for 2001-2002 Elantra
- Rundown on "The Plan".
- Stuff won't fit 2K2?
- ECU Upgrade for 2000 elantra
- Brand new pics
- ECU upgrade for a 98 Elantra
- 17" on elantra?
- 2000 Elantra Mods & Times?
- 4-2-1 headers on 2000 Elantra
- MAF or MAP and Temp sensor.
- Elantra GT vs. Altima
- 2001 Elantra
- 98 Elantra IM(RANDOM?)
- What can I do to my 2001 Elantra???
- elantra body kit??
- Beta High Intake Cam
- '97 5-Speed Elantras
- HSPWR 97 Elantra
- Big Bore Throttle Body
- Gauge Change 2000 Elantra
- SCCA mods ????
- new body kit for 2000-2001 elantra
- Elantra GT Opinions?
- intake removal problem
- compression ration
- Elantra Blue on White Gauges!
- Strange Noises
- ECU Question
- Mods for the 2002 Elantra
- 2001 Hyundai Elantra Recall
- upgrade for 97 elantra wagon
- Rims for 2000 Elantra
- 2001 Elantra Head Unit Swap
- Damned Fine 2001 Elantra Kits!
- Will Tib rotors fit my Elantra???
- Elantra bulb sizes???
- Header install on 99 - 2k Elantras & Tibbys
- '94 Elantra 1.6L intake options???
- 2000 elantra
- Need all the info i can find for my 94 elantra
- 2001 Elantra
- Body kits for 2k1 elantras
- Dragon r intake question
