tip (or older elantra header) on a 99 elantra
Old Apr 30, 2002 | 02:58 PM
j.d.roost's Avatar
Default tip (or older elantra header) on a 99 elantra
Hello ,I have a good used tibby (98) factory header and want to replace my girls "catafold" on her 99 elantra. I can weld in a 02 hole (for the older tib. manifold)but am worried about the pre/post o2 reading ( I am sure it will set off a cat.insufficiency code,because the front cat. would be gone )
so I am looking for a workaround. Any ideas/experiences?
Thanks
jd
Old Apr 30, 2002 | 04:34 PM
Why not just install headers?
I don't understand the question...are you removing your cat entirely? If so, I will simply not support that question with an answer. A proper cat does wonders to clean up your exhaust emissions and does not significantly lower your HP.
If you were to just MOVE the cat to under the car (like you had installed headers, then you would just lengthen the o2 sensor wires and put one in front of the cat and one behind the cat.
Old May 1, 2002 | 07:47 AM
j.d.roost's Avatar
Well as far as the no cat deal, I was more interested on removing the huge front cat restriction ( off road only, if that makes things politically correct) Yes a high flow cat could be used further back in the exhaust( I actually have a good tib. center cat I can use)
I am worried that by moving the o2s
the heat range will be different from factory and through a ce light.
Have people done this mod?
While I agree with the 1st part wholeheartedly.
The factory front cat is a huge performance block.
Thanks
Old May 1, 2002 | 07:54 AM
j.d.roost's Avatar
found a similar topic in search.
Thanks again
