Swoosh Rpm Guage HELP
Old Jan 8, 2011 | 12:04 PM
AvanteKing's Avatar
Vehicle: 1998 Elantra
Default Swoosh Rpm Guage HELP
Hi i ordered a swoosh stepper rpm guage, theres a ground and rpm signal wire, where can i pull the rpm signal from the ecu? or any other source, its a 1998 hyundai elantra base model
Old Jan 8, 2011 | 09:09 PM
www.HMAservice.com
login: RDTiburon.com
pw: tiburon
https://www.hyundaiaftermarket.org/f...edo-ecu-wires/
On the RD Tiburon, it was a white wire and pin 47 on the ECU. It's probably a different ECU, but they may have used the white wire again on the gauge cluster.
Someone with an Elantra (post #3) said their wire was white with a green stripe. Tiburon owners have reported it's a white wire in the gauge cluster.
https://www.hyundaiaftermarket.org/f...wiring-diagram
Obviously the ecu wires are not the same.. But you get the gist.... I just found the correct pin-outs from the Elantra ECU. My tach wire was a solid white with a green stripe. I dont know why they had to use different colors for each car. Silly Hyundai...
Old Jan 9, 2011 | 10:27 AM
AvanteKing's Avatar
Originally Posted by majik
www.HMAservice.com
pw: tiburon
thank you, i tried wiring it to the ignition coil and the rpm guage just goes insane idk wat was wrong with it, so better just wire it to ecu
